explain the bind node (vopsop) ? what isi it where to work ?
6606 1 0-
- saeed33
- 20 posts
- bonsak
- 459 posts
Hi
If you have an attribute upstream from your attribute vop that is not exposed in the global parameters node (f.x @myattribute), you can use bind to “import” it into your vop network. If you want “myattribute” to continue down stream from the attribute vop, you use the bind export node to “export” it
The “import {type} attribute” does the same.
-b
The “import {type} attribute” does the same.-b
