is there a way to do batch renders of multiple hip files inside houdini?
Hqueue maybe?
I've being looking on the web and all I can find is command line instruction to render outside of houdini.
batch rendering... (newbie question)
2038 1 1-
- Nicolas Heluani
- 312 posts
- Nicolas Heluani
- 312 posts
So it seems that HqueueServer and Client in the same machine is the way to go…. and it was surprisingly rather easy to set up, once I learn that I have to uncheck Generate IFD files since I am using Indie. So if anyone out there having the same problem there you go.
Now the issue I have is that for some reason Hqueue is very slow rendering compared to when I render directly from Houdini. :?
Edited by Nicolas Heluani - May 17, 2016 17:21:44
