Fractal Geometry
   3334   1   0
I am not so sure if what I am doing is going to be of any use but I wanted to play with the for loops and for each subnetworks to do a fractal geometry extrusion. I still have to polish how the inset distance is calculated as the formula that I use (distance to the center point divided by a factor of around 0.3 works well for triangles but not for rectangles shapes. However the major issue is that Houdini crashes if I make the itteration above 3. I was hoping to be able to push it a lot more than that. Right now I hope is a problem with the inset going below 0 or something like that. But as of now I am having fun…
I am putting the hip file here if anyone also wants to play around….
Niconico.
FractalGeo.hiplc (354.3 KB)
https://www.imdb.com/name/nm8408875/ [www.imdb.com]
Sorry forgot to add the picture describing the fractal….
