wheel mouse zoom both in viewer and tear off network panel
   5878   4   2
Howdy,
I like to tear off my parameters and network editor and pop them on my second monitor to increase my work space. Through habit (from using max) I sometimes roll my wheel mouse to zoom (dolly) and it occurs simultaneously in the viewer and torn off network editor. This doesn't happen when the editor is docked. It slows me up a bit because when I check my network I have dig around to find the tile I was working on.
I was hoping side effects would fix this with H8. A tiny gripe otherwise for a very elegant interface.
It seems to be fine with the spacebar + MMB.
Gurbo
Gurbo
______________________________
Still on my training wheels
I second this, I have mentioned to support in the past.
-Drew
Are you using Houdini 7.0? If so, could you try Houdini 8.0?
Yes, I was thinking of 7. Seems fixed in 8, thanks!
-Drew
You're right!
However I found that it does this in version 8.0314. That release was a little buggy so I downloaded the latest build (8.0345).
Surprising how a little thing like that can effect one's efforts.
Thanks for your patience.
Gurbo
