After chaning Object radius animation does not work anymore. (Project file attached)
3647 4 1-
- ISUther
- 116 posts
- Enivob
- 2658 posts
Press the D-KEY while your mouse is in the 3D viewport. Change your background style to light instead of dark. What is happening is that when you change the scale-Y the particles are now colored black instead of red. When viewing them on a black background it seems like they have disappeared but they really are there.
Notice your vex code. When @accum is zero the color will be black.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- ISUther
- 116 posts
Aha. Thnx.
Saddly im not pro with the vex
Maby u can take a look at this?
I have set up lighting and everything in black background and i was able to see object and everything here (also saved before i went to sleep) and today when i did open up file i did not see my object any more also seems that when i make changes to “mountain1” node i do not see animation any more.
I wanted to render out animation where first egg evolves from that growth thingy and then it starts to bit by bit glow insidd and thro those small holes or fractures (as u see in picture) light glows out. (look at attachment)
I also added cine file.
May be you can help me out to fix it?
What am i dooing wrong there?
I also get bit confused regarding selection nodes.
Blue button makes them visible or not visible.
Red turns them off
but purple?
Some times i have selected purple on some other node and blue another and i get interesting result. Will that be also same when i render out?
Red turns them off
but purple?
Edited by ISUther - July 22, 2016 16:17:27
- Enivob
- 2658 posts
- _Christopher_
- 767 posts
