What is Color Value Range of @Cd
   6027   8   1
I was hoping someone might be able to clarify what the value range is of the @Cd attribute.
The docs say it is a vector of 3 floats but I haven't been able to find what the actual range is.
My understanding was that each float in the vector representing the respective RBG values would be from 0-1.
However in experimenting with values it seems that the actual range is from 0 to 2.55 ;
Representing a scaled representation of 0 to 255.
The reason I say that because ( in the file attacted in which I test the different red values of the first float of the vector ) I can see a change in the brightness of say setting the red value to 2.01 then changing it 2.55.
The span of change ( for my eyes at least ) needs to be about that of 0.4 difference, and I can see differences in color for any change less than 2.55
If I set it to 2.55 then change it to 6.0, I see no change which is why I'm led to believe the range is 0 to 2.55 and not 0 to 1.
Can anyone concur or am I misunderstanding whats going on?
Test Cd color range.hiplc (64.3 KB)
Upper bound appears to be @Cd = 1e38
Lower bound appears to be @Cd = 1e-45
The viewport display 0-1 range only, turn on HDR Rendering too, in Display options/Effects
Forgive my lack of math notation.
When you say 1e38 your meaning the hex value? and not exponent value of one? such that 1 times itself 38 times? which if it was only gives 1 anyways.
And in the viewport if the display is only for 0-1 how come I can see differences say between 1.8 and 2.5 or even 1 and 1.9?
And yes for all my testing so far I have had HDR set as you say.
Thanks.
Edited by BabaJ - Aug. 16, 2016 14:41:36
https://en.wikipedia.org/wiki/Scientific_notation [en.wikipedia.org]
1e38 = 100,000,000,000,000,000,000,000,000,000,000,000,000
Training Lead
www.sidefx.com
BabaJ
You ‘default diffuse’ in Display Option/Effects is probably not set to one.
Thanks for the ‘math’ lesson Arctor…I should have known that…geesh.
So my diffuse was set to 0.4 for all 3 values and I changed it to 1 for all 3 and turned off specular, ambient and emission.
But I still can see differences between say 1, 1.5 and 3
But it's ok, it doesn't matter…starting to see something important to keep in mind as I build my vex functions.
With such a big range possible for values ( 1e38, 1e-45 ) and seeing how what I end up actually getting; It depends on where I actually end up having those values “piped” too.
In one case with Artyes' feedback he's showing me there's some viewport settings that determine the end result.
And I guess when I get to the part of working out shaders/lighting for my vex created objects I am going to have to give similar considerations; How those color values will be “interpreted”.
So once I work through that I'll have to work out how I want to setup my color algorithm settings for patterns within the vex code I'm writting.
Thanks guys for your usefull feedback.
BabaJ
Make sure to ‘disable lighting’ too. light bulb with x in it, right side of toolbar.
Yeah…disabled lighting too…
..and still can see a difference between 1 and 6.
I looked around for other possibilites like I tried setting gamma to 0…and also tried switching out scene viewports ( create new, close old ).
it's ok though…although you've got me interested in why…lol
Unless you have viewport colour correct then I can't reproduce that one.
