Hi all,
I am new to Houdini so my apologies if this is if I am missing something simple here. I have a sphere that I used an Attribute VOP to displace points and add hills. I want to be able to export a heightmap based on the displacement.
I think to do this I would have to somehow export the value from my Displace Along Normal node but I do not know how to do this. I tried a Point Cloud Export but that does not seem to be right.
I have added a pic of my original sphere, the displaced sphere and the network. I have also uploaded my .hiplc if that helps anyone.
Thank you,
Clint
Export Heightmap
7715 3 1-
- Clinton Walsh
- 8 posts
- goldfarb
- 3465 posts
- Clinton Walsh
- 8 posts
- brianBurke
- 192 posts
howdy clinton. to export your displacement value as a texture map, using texture baking will be your best bet. you can plug your displacement amount value into color (Cd), make a constant shader where point color is output directly as surface color, and then use the the bake texture render node [sidefx.com] to output your displacement color as a texture.
if you do all of the work in a shader (at the sample level rather than at the geometric level in SOPs), you'll get more detail in your texture map.
-b
-b
