Delete Isolated points in Cloud points
   20988   13   0
Hi everyone,
I’m new in Houdini and I try to do some geometry from points cloud.
First I wanna clan my point cloud from Alembic file because I have some points wrong, isolate than another points so I need to delet this point and then try to connect this points to create a geometry.
Now I was trying to create a group and then delete it, but I don’t know what expression I need to use in Attribute Create or Attribute Wrangle, to select the isolate points with some dynamic value.
I this picture you can see my points.
Just select the ones you do not want in the viewport and press the delete key. This will generate a Blast node with the point numbers in the pattern field. Those numbers can be used for further processing as well. Or copy those numbers into the Group field for a group node to make them a group.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Thanks Enivob,
I can't select all points they are in all the cloud, like 29 millions in total. I need to create a smart selection by radius and try to select the isolated points in all of the cloud. I have small zones, I can't access.
Another idea?
Thanks everybody
There is definitely more procedural way to delete points.. it will be helpful if you post your file.
Hi! sure
Hi this is an example.
TestPoints_02.hipnc (80.9 KB)
You need to press the lock btn to get the geo
Just do a group by bounding using the sphere option and that will get you all points within a certain radius. Same workflow applies. Delete or Blast them after you have the group.
I'm sorry I thought houdini attached it automatically.
Thanks Sepu, I attached the file again.
Edited by magolalipson - Jan. 31, 2017 12:57:23
TestPoints_02.hipnc (353.7 KB)
Maybe with this example is easier to understand!
I can't select the points in the air only if I make a selection as a radius from every particle, if this particle doesn’t find a another particle it’s one of I want to delete.
This is the reason I think I need to use Attribute Create or Attribute Wrangle o group I’m not sure.
Thanks if someone any idea.
Tetera_Geo.hipnc (3.5 MB)
try Fuse Sop
check Keep Unused Points and play with the distance
EDIT: I read it wrong:
try doing this in point wrangle:
int pts[] = nearpoints(0, @P, chf("radius"),2);
if (len(pts)==1){
    removepoint(0,@ptnum);
Edited by tamte - Jan. 31, 2017 23:54:10
Hi Tamte,
Your syntax was an advance thanks, it’s works!! Now I see I need one more think?
I need only one network of points (the biggest), so I need to see only a points who are connected with another point (radius 2). I don’t want a net point more far than radius value.
It’s hard to explain.
Do you recommend me some tutorial for learn how can I read this kind of syntax’s in Vex?
Thanks People
the file
Tetera_Geo3.hipnc (4.7 MB)
the points
Just add a facet node, click remove inline points and play with the distance.
You welcome.
Edited by Adetayo - June 5, 2021 14:17:56
