Material Tiling Issue - I want it to NOT tile, but it's tiling
   5558   6   2
OK, so I've created a grid with a few rows and columns and I also created a 2-sided material using isfrontface and a switch in a Material Shader Builder.
My problem is that it ends up tiling my image depending on how many rows/columns I have, and that's not what I want.
I need the extra geo in the rows/columns so I can bend this smoothly.
I'm at a loss as to how to fix this. I've tried all kinds of UV Projection, UV Edit, etc. nodes, but nothing seems to help.
Any ideas?
Thanks,
Jim
Edited by reelinspirations - Feb. 10, 2017 15:54:46
tiling_issue.hiplc (191.0 KB)
Reel Inpsirations
Houdini Work in Progress [vimeo.com]
Try adding UVs to your grid.
Then inside your shader use a Bind to fetch that attribute into the shader network. It should come in as a vector. Route the X and Y from the VectorToFloat node to the S and T inputs of the textures.
Edited by Enivob - Feb. 10, 2017 16:30:57
ap_tiling_issue.hiplc (175.7 KB)
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
So, I haven't used bind at all yet, but I think what's happening is that you are accessing the uv attribute that the uvtexture SOP created, then creating a float out of it, but you only need the first 2 as it's not 3D information.
Not sure what the S and T inputs stand for, but it works and I am very thankful to you for that!
Jim
Reel Inpsirations
That worked great, except now my texture is reversed. I've tried UVtransform both using a SOP on the grid and in the texture and can't seem to figure out how to get it flipped.
Any ideas?
Reel Inpsirations
OK, I figured out a ‘work around’ but not sure if it's a ‘proper’ way to do this.
I swapped the S-T inputs and then rotated the UV in the uvtexture and offset it by -1 in the X and it worked.
Not sure why it worked, but it did.
Reel Inpsirations
just as a sidenote:
the s and t are just u and v.
U = S = X
V = T = Y
A note for Googlers if you're using MTLX.
If you DON'T want imported texture (MTLX Image node) to tile:
- change "Address Mode" U and V parameters to constant. By default, it's set to periodic which means - tiling.
If you want to scale, offset, or rotate, here's my approach (MTLX Geometry Property value node fetches st(UVs in USD) value from geomprop param):
Edited by AnimGraphLab - April 15, 2024 03:21:03
Generalist. Transforming still images to 3D animation 🔮
Socials: https://linktr.ee/AnimGraphLab [linktr.ee]
