I am doing some pyro simulation, exporting result as VDB. I have the following two questions:
1) Is it possible to see the max/min range for temperature and density fields? Even more, can I see the entire range of values in a list view just as we view point attributes in the geometry spreadsheet? I want to do so because I am rendering in an external renderer and it will help see the values of density/temperature so I can fine tune the renderer shading parameters…
2) I am not sure if this is even valid for not, but Houdini produces one VDB per frame (i.e. when I use ROP output driver, it stores file.01.vdb, file.02.vdb or in general file.$F.vdb). Now, my question is there such a thing to store ALL vdb files in one big file? i.e. one file that has vdb in different time frames? I am not sure if this exists or not, but I am just doing some basic research…
Thanks,
VDB questions
6955 7 1-
- catchyid
- 68 posts
- jsmack
- 8177 posts
- VDB primitives lack min/max intrinsics, but you can use a volume slice and play with min/max values and watch the colors.
- Why would you want a value spreadsheet? A list of millions of values seems of little use. The volume slice SOP is useful for visualizing ranges/prevalence of values.
- There is no multi-frame vdb storage container that I know of. If you want to make an archive just for storage purposes, you could tarball or zip them up. For rendering/use they would need to be extracted.
- catchyid
- 68 posts
- tamte
- 9380 posts
to see all the values in spreadsheet you can use VDB Visualize Tree
uncheck everything except Active Voxels and check Points With values, then you will see values of all voxel values in spreadsheet
or as jsmack indirectly hinted, to get just min/max you can convert to houdini voulume and then look at volumeminvalue/volumemaxvalue intrinsics or use Volume Reduce
- catchyid
- 68 posts
- catchyid
- 68 posts
- buki
- 1773 posts
also there is a check box on Dop Import Fields sop, compute min max, you can examine those as primitive attribs for each field
Edited by buki - April 4, 2017 23:26:21
daniel bukovec | senior fx td | weta digital
qLib -- http://qlab.github.io/qLib/ [qlab.github.io]
- lewis_T
- 269 posts
I don't really need to see ALL values
