I've got 2 seemingly identical shapes, but when I get the oriented bounding boxes they are notably different. I looks like there's some hidden data I didn't know it existed.
Please check the file, can you tell what's going on ?
Oriented bounding boxes not consistently oriented
4712 3 1-
- A-OC
- 257 posts
- Doudini
- 333 posts
this is really weird. not sure what the current state is in finding the oriented bounding box but it seems there could be a better algorithm in houdini. i often saw cases where the orientation seems way off.
Not sure what is happening in your case as the geo seems pretty much identical. you should report it directly to sidefx support.
- jlait
- 6818 posts
Finding optimal bounding boxes is a very hard problem.
https://en.wikipedia.org/wiki/Minimum_bounding_box_algorithms [en.wikipedia.org]
Also note that “smallest bounding volume” isn't necessarily what we intuitively imagine when we want the smallest box. Usually we also prescribe some axis of symmetry to further constrain the results and find it odd when the result doesn't reflect this.
Anyways, in this case the objects are not equal. If you do an Attribute Wrangle and wire both in with
@P -= @opinput1_P;
and look at the geometry spreadsheet you will see lots of 1e-7 level differences between the models.
This model doesn't have a unique smallest bounding box, there is more than one way to skin this cat. In partciular, if I compute the volume of the two output bounding boxes I get pretty much the same result, suggesting this is just switching between two valid solutions.
@P -= @opinput1_P;
- A-OC
- 257 posts
