A newat feature of ICE is to inspect things in the viewport in context. But it always annoyed me a little I had to set attributes to check them.
I there a quick way to do that here in without having to “bind export” in a VOP or to i@atribute in VEX?
I notice that the visualizers work with say “P”,“N”,“Cd” but not, for example, “ptnum”, “primnum”, “numpt”, “numprim”. Funny enough the former are in green and the latter in blue in the VOPs
http://i.imgur.com/U6hfBAH.png [i.imgur.com]
What's the quickest way to check these? I know I have display options to have text markers for “ptnum”, “primnum” and “vtxnum”, but not the others.
If I bind “numpt” to a parameter either in VOP or VEX, then the visualizer marker works if I call the parameter set.
Quick way to check VEX/VOP atributes without binding?
5133 5 0-
- probiner
- 372 posts
- BabaJ
- 2164 posts
- jsmack
- 8177 posts
The quickest way to see number of points or primitives, etc is to middle mouse over a node, or hit the ‘i’ on the node hover ring, to open the info window. This will show detailed information about the number and types of geometry present, as well as attributes and groups. This info is a vital part of debugging a vex workflow. I'm not sure of the usefulness of seeing total number of points in the viewport, but if you really want it you could send in an RFE.
Note, the blue/green etc color coding of vops is the data type. Blue for integers, teal for floats, green for vectors.
Edited by jsmack - May 13, 2017 15:05:03
- probiner
- 372 posts
BabaJWhere should this go? I've tried it on a Attribute Wrangler.
I use printf function often, which will pop up a little console window.
You could do something like:printf("My Check of ptnum is %g\n\", @ptnum);
http://i.imgur.com/CKe7TRa.png [i.imgur.com]
This is not just for “numpt”, but to grasp how I can quickly visualize things in context.
Thank you both.
Edited by probiner - May 14, 2017 10:32:17
- BabaJ
- 2164 posts
- probiner
- 372 posts
