BUG: Scoping raytracing in VOPs
   5141   6   2
Using the Trace VOP, I attach a Parameter set to List of Objects to the Scope input. When I try to use it, however, I notice a couple of unfortunate things. Blank means everything, which IMHO is wrong (should be * means everything!) and I cannot do /obj/nothing as a workaround, it also gives me everything!
Strangely, if I set my ROP to have Visible Objects set to only the obj with the raytrace shader on it, I can use another object that is not in the Visible Objects list, and that will effectively set the Trace scope to none.
Peter B
Peter Bowmar
____________
I have submitted a bug to look into that. But, to clarify, the bug is about the inability to set nothing as a scope argument to the raytrace VOP, right?
Yeah, you should be able to set it to a blank field and have nothing be raytraced against (for that particular raytrace call).
Peter b
Peter Bowmar
____________
BTW: asking around I've learnt that an empty string means to use the default reflection mask defined by the object which is probably set to “*”.
Hi Rafal,
Interesting and unintuitive ) I say unintuitive because it's called Reflection Mask, yet the raytrace scoping might be for something entirely unrelated… Ah well, now I know )
Peter B
Peter Bowmar
____________
So raytrace calls in Mantra use the object reflection mask a an object set to know what againt to throw rays?
So i can use the reflection mask to limit the objects to throw rays to?
Un saludo
Best Regards
Pablo Giménez
Whats interesting about the VEX trace calls is that the instant you specify the “scope” argument that it'll ignore the Scope parameter in Object's parameters and use only what is specified to VEX. I personally wish the masks would be combined but what you can do is use the renderstate() function to find out what the object level mask should be and optionally use it instead. To this end it'd be great to have the Raytrace VOP support using the renderstate() functionality too.
