I'm trying to constraint a curve to 90 degree by using attribute wrangle in DETAIL mode like as follow:
//read value from attribute:“edgedist” at index attrIndex
float ReadDistAttr(int arrIndex)
int suc;
float retDist= getattrib(0,“point”, “edgedist”,arrIndex,suc);
return retDist;
float ReadAngleAttr(int arrIndex)
int suc;
float retDist= getattrib(0,“point”, “fixedAng”,arrIndex,suc);
return retDist;
vector curPt,nextPt,crossV,targetPt;
for( int i=0;i<@numpt-1;i++)
curPt= point(0,“P”,i);
nextPt= point(0,“P”,i+1);
vector vecDiffNextCurNorm=normalize(nextPt-curPt);
float ang=ReadAngleAttr(i+1);
//addpoint(0,crossV+nextPt);
if( ang>0 && ang<=135 )
crossV=cross(vecDiffNextCurNorm,{0,1,0})*ReadDistAttr(i+1);
targetPt=crossV+nextPt;
setpointattrib(geoself(), “P”,i+2,targetPt);
//addpoint(0,targetPt);
else if( ang>225 && ang<=360 )
crossV=-cross(vecDiffNextCurNorm,{0,1,0})*ReadDistAttr(i+1);
The problem is that the calculation always refer to the original points and not to the points that modified by setpointattrib function.
Help please
setpointattrib not updating
2651 1 2-
- yali
- 1 posts
- neil_math_comp
- 1743 posts
VEX only ever reads from the input geometry and writes to the output geometry, (with the caveat that attributes bound to VEX variables via the @ syntax can give the illusion of reading from the output, but it'll just be reading from a VEX variable, and that only gives access to the “current” element of that attribute). If you need to read from the output geometry, you either need a For Loop SOP block, or a separate Attribute Wrangle. In your case, however, that shouldn't be necessary, because your code only writes to positions two points ahead, so you can just keep track of the P values written using two vector variables, and you already have those variables, e.g.:
vector curPt= point(0,"P",0); vector nextPt= point(0,"P",1); for( int i=0;i<@numpt-1;i++) { vector vecDiffNextCurNorm=normalize(nextPt-curPt); float ang=ReadAngleAttr(i+1); //addpoint(0,crossV+nextPt); vector targetPt; if( ang>0 && ang<=135 ) { vector crossV=cross(vecDiffNextCurNorm,{0,1,0})*ReadDistAttr(i+1); targetPt=crossV+nextPt; setpointattrib(geoself(), "P",i+2,targetPt); //addpoint(0,targetPt); } else if( ang>225 && ang<=360 ) { vector crossV=-cross(vecDiffNextCurNorm,{0,1,0})*ReadDistAttr(i+1); targetPt=crossV+nextPt; setpointattrib(geoself(), "P",i+2,targetPt); //addpoint(0,targetPt); } else if( i<@numpt-2 ) { targetPt = point(0,"P",i+2); } // Shift back the point position variables for the next iteration curPt = nextPt; nextPt = targetPt; }
