(This is a duplicate of a question sent out on the list.)
Hello All,
Still muddling my way through VEX.
As an example… I have an Attribute Wrangle with 3 inputs.
Input 1: some geometry
Input 2: a single animating point
Input 3: another single animating point
If I have the following vex snippet… (the actual function is more complex.)
float test = 1.2;
@P = @P * test;
All points will have their xyz values multiplied by “test”.
But if I have…
float test = distance(@opinput1_P, @opinput2_P);
@P = @P * test;
Only the first point will have it’s xyz values multiplied by “test”.
Any help appreciated.
Simple VEX Question
3609 3 2-
- fgillis
- 157 posts
- malbrecht
- 806 posts
Moin, Floyd,
currently VEX does not seem to support calculations/autocasts on assignments. Casting a vector from a single float is an overloaded function (“autocasting” from a single value to three) - and that, too, is not supported (yet?).
You can wrap the cast into a function, though: By writing
you use the “workaround” of sending your float “test” to a function first that takes care of the casting and returns a vector for the interpreter to use for “@P”.
Marc
@P = @P * set(test);
Marc
Good bye.
Good bye.
- jlait
- 6744 posts
That should work as written. Possible problems:
@opinput uses `id` attribute if it exists to match pairs of points so it works with particle systems for free. This becomes surprising if you have an `id` attribute that means something else. Under Bindings, erase the default `id` for attributes to match.
There may still be annoying bugs with VEX not refreshing its bindings cache when @opinput is used when nodes re-wire. Adding some white space to your wrangle will force a re-cache. If this does fix it and you can reproduce, please submit a bug as we want to fix these bugs. (For performance, we don't re-scan all the attributes when we re-cook if we think they are the same, but @opinput bindings have confused this in the past)
- fgillis
- 157 posts
Thank you Marc & Jeff for your suggestions.
I ended up merging the 2 “animated single points” into the geometry I wanted to manipulate and accessed them with point functions instead…
vector pnt_A = point(0, “P”, 1001);
vector pnt_B = point(0, “P”, 1002);
Then did the distance calculation like so…
vector dist = distance(pnt_A, pnt_B);
Then the following worked fine…
@P = @P * dist;
Again, this was just a simplified segment of a complex hscript expression I was trying to update to VEX.
Damn, VEX is fast! If I'm not careful I'll become a convert.
@P = @P * dist;
Edited by fgillis - July 15, 2017 03:54:25
Floyd Gillis
