Hard Edges
   6404   6   1
Hi
I was looking for a way to mark/group edges and make them hard in terms of smoothing and this is what I came up with:
I couldn't find a standard way to do this. Maybe an edge option in the Normal node would be cool.
Cheers
Edited by probiner - July 22, 2017 12:04:29
HardEdges.hipnc (104.3 KB)
If you want to do this on a per primitive basis select some as a group, add Vertex Normals and change cusp to the desired value. For a single patch select some edges and use the Edge Cusp operator from the shelf.
Hope this helps.
HardEdges_01.hipnc (125.4 KB)
Hey Cerimon, thanks for adding more alternatives.
I'm my case the intention was really to do hard edge marking alike Blender/Maya/XSI.
Cheers!
Edited by probiner - July 21, 2017 14:47:46
I just noticed though that while you can't set the normals on edges, you can use a group of edges… So there's that…. x)
Edge Group > Set on Vertices with 0 threshold!
​​​​​​​Eh!
The issue with the solution provided with Cusp : you litteraly cut the geometry and it gives overlapping points...
I'm surprised Houdini does not provide simple tool to crease/hard edge as you can do with other software like Max.
Pacman972
Hello @Pacman972, I think you miss the @probiner response that give you the straigth way to do this without litteraly cut the geo.
Cf. below quick illustrated example, hope that help.
Hi Julca ! Indeed with illustrated example, it's better ! Thank you !
