i'm building a rooftile generator. But i can't wrap my head around it.
My idea was to move each primitive to the origin and orient it so i can project the points on it and then use the copy sop to copy the tiles on it. As a test i did the folowing steps:
1 create a grid.
2 transform the grid arbitrary for testing purposes
3 add a primitive normal
4 create a left attribute by calculating the cross(@N, {0,1,0});
5 create a up attribute by calculating the cross(@left, @N)
6 move the prim to the origin by using the primitive node with Do Transformations on and match normals
7 here i want to calculate the rotation angles. But i can't get the correct angles so it matches the grid in step 1
after step 7 i want to measure the bounds and project the points on the primitive and copy the tiles
any ideas?
with kind regards,
gilbert
how to project rooftiles on a primitive? [SOLVED]
2451 3 2-
- mmwizard
- 22 posts
- mmwizard
- 22 posts
Well i solved it by myself. In short, i took another aproach by going trough the folowing steps:
1 for each primitive i order the points to lefttop, leftbottom, righttop and rightbottom.
2 calculate height and width using the vectors from step 1.
3 calculate county and countx by using the tilesize
4 find stepsize and direction
5 create points.
5 create points.
- Konstantin Magnus
- 744 posts
You can also turn primitives into roof tiles.
- mmwizard
- 22 posts
Well that is a great solution. Only i think this does not fit my needs. What i want is to rough out the general shape of my building and then select the roof primitives to place the rooftiles on. This can be a straight roof but also a L, T or + shaped roof. But it is definitly interesting to see youre aproach. Thank you…
