Drive position from UV. What am I doing wrong here?
   3446   2   0
I need to add new points on a curve using some arbitrary UV values.
I convert the curve to nurbs, and use the “UV texture” node set to points and type “arc length Spline”
The points are so lined up straight from 0 to 1 and they seem to keep their relative distance from each other.
The problem arises when I try to use the “primuv” function in a wrangle to retrieve the world position of an arbitrary UV value.
You can clearly see it in the attached file: even if I feed the primuv function with the UV value of specific point of the curve, the returned position doesn't match the position of the point used.
What am I missing?
Any help much appreciated!
cheers
position_from_UV.hiplc (81.7 KB)
primuv uses the implicit parametric coordinates of the surface or curve. The uv attribute cannot be used to retrieve a position in this way.
ah thanks for the info, I wasn't aware about it…
then I'm going to use these implicit uvs, although it's less elegant (in my case)
but still, I would love to learn how to do that with texture UVs.
Anybody has any hint?
