Loop Selectors: Crash Bug (and a RFE.)
   5665   5   1
Houdini 8.0.481
1. Fresh Houdini
2. Go to SOPs and create a Grid
3. Hit “s” to select some points/primitives
4. Set your selection to - (Remove from selection).
5. Click on a prm/point, you won't see the selection since you are in “Remove from selection” mode.
5. Hit “r”
Crash.
OP3D_EdgeLoopHelper::rotateDirection(GU_Selection&, int, bool) (??:0)
OP3D_EdgeLoopHelper::handleKeyEvent(UI_Event*, DM_Viewport&, GU_Selection const*, bool&, bool) (??:0)
OP3D_InputSelector::handleKeyEvent(UI_Event*, DM_Viewport&) (??:0)
OP3D_SelectState::handleKeyTypeEvent(UI_Event*, BM_Viewport&) (??:0)
BM_SimpleState::handleKeyEvent(UI_Event*) (??:0)
DM_SceneManager::handleKeyEvent(UI_Event*) (??:0)
DM_Workbench::handleKeyEvent(UI_Event*) (??:0)
DM_ViewData::handleKeyEvent(UI_Event*) (??:0)
OP3D_View::handleKeyEvent(UI_Event*) (??:0)
FUSE_Viewer::handleKeyboardEvent(UI_Event*) (??:0)
UI_Queue::processNextEvent() (??:0)
UI_Queue::drain() (??:0)
UI_Queue::eventLoop() (??:0)
main_part2(int, char**) (AP_Main.C:0)
main (??:0)
Aside from fixing the null pointer or whatever is causing the crash, a nice RFE would be the ability to use the Loop Selectors to unselect things too.
I'm always using the loop selectors to drive around the surface picking points and primitives, but there are times where I'd like to drive back over some geometry unselecting as I go instead.
Drive == hitting (r or R and f)
I am agree:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=5187 [sidefx.com]
Un saludo
Best Regards
Pablo Giménez
Actually I found that bug while I was trying to figure out what you were talking about in your post.
I can only reproduce this with primitives and not with points.
edward
Bah..so that's what I get for not testing with Points or Edges.
:wink:
Thanks for reporting the crashing bug Jim… should be fixed as of 8.0.488.
Take care,
George.
