Does anyone know the reason why there isn't a boolean attribute type in Houdini?
I know you can make one with a simple integer value but the reason behind boolean attributes themselves is for the small footprint. And in houdini we find ourselves often working on the millions of points so any reduction of data helps right?
And I know you can define a boolean with a simple relation with an integer, float or even vector. I was thinking in performance. While a integer value is a 32 bit attribute with a huge range traditionally a boolean attribute is just 1 or 0, very efficient when dealing with huge amount of data.
Maybe a 1 or 0 int is the same footprint as a boolean attribute?
boolean attributes vs int attributes
4186 3 1-
- Nicolas Heluani
- 303 posts
- Olaf Finkbeiner
- 323 posts
Hi Nicolas,
you can create a 8bit integer attribute for a boolean see:
http://www.sidefx.com/docs/houdini15.0/nodes/sop/attribcast [www.sidefx.com]
regards
Olaf
regards
Olaf
- Nicolas Heluani
- 303 posts
Olaf FinkbeinerThank you very much!
Hi Nicolas,
regards
Olaf
- Nima
- 471 posts
