How could I promote an attribute in wrangle?
   3470   4   0
Hi guys;
In a point wrangle, I want to get the Normal of a specified primitive (from input geometry) and pass the value as @MyNewNormal point attribute to output. (Normal from a “Primitive” to Normal of a “Point”)
I tried these codes, but it doen't work:
int PrimNumber;
vector Prim_uv;
float maxdist = 10;
float dist = xyzdist(1, @P, PrimNumber, Prim_uv, ch("MaxDist"));
i@PrimNumber = PrimNumber;
v@MyNewNormal = prim(1, "N", PrimNumber);
Edited by Masoud - Oct. 16, 2017 04:09:25
Masoud Saadatmand (MSDVFX)
If you want to get the normal from a specific prim (f.ex prim zero) you can use:
int success;
v@N = primattrib(1, 'N', 0, success);
By using xyzdist you get the normal from the primitive that is closest to the point your wrangle is running over.
-b
http://www.racecar.no [www.racecar.no]
Thank you bonsak;
As you said, I tried xyzdist, and it worked:
vector Norm = xyzdist(1, @N, PrimNumber, Prim_uv, ch("MaxDist"));
@N=Norm;
Masoud
Thank you bonsak;
@N=Norm;
xyzdist just returns the float distance, so if it looks like it works in your case, it may just be a coincidence
to get the real primitive normal use:
int pid;
vector puv;
xyzdist(1, @P, pid, puv, ch("MaxDist"));
if (pid!=-1) {
    @N = prim_normal(1, pid, puv);
if you want interpolated normal in case vertex or point N exists then:
int pid;
vector puv;
if (pid!=-1) {
    @N = primuv(1, "N", pid, puv);
Thank you “Tamte”
You are right, it was my mistake.
