Redshift 3D [www.redshift3d.com] has released version 2.5.42 which adds support for GPU rendering with Houdini 16.5!
EDIT: There was a problem with the 2.5.41 release that caused issues on some Windows platforms. After some discussion with SideFX, Redshift release 2.5.42 resolved the issue so that Houdini 16.5 is fully supported by Redshift across all platforms.
Redshift3D adds support for Houdini 16.5
13771 9 2-
- TwinSnakes007
- 651 posts
- jsmack
- 8195 posts
- sepu
- 474 posts
- Marcolax
- 21 posts
- anon_user_37409885
- 4189 posts
- TwinSnakes007
- 651 posts
Marcolax
After spending 4hrs trying to figure out, i want to let the community know that the redshift demo 2.5.32 version only works with Houdini 16.0.705.
I'm sure that in a near future this will change though.
Hi Marcolax, sorry to hear about your troubles.
Redshift is built against HDK versions, not Houdini versions (they are not the same thing). So, Redshift supports multiple HDK versions, allowing it to fit into alot more pipelines that are using various Major Versions of Houdini.
This also allows Redshift to work with Daily Builds of Houdini, so, as you noticed, the Redshift version 2.5.32 Demo that you downloaded works with Houdini version 16.0.705, but it will also work with Daily Builds of Houdini 16.0.x, such as the latest Daily Build of Houdini 16.0.785
Houdini Indie
Karma/Redshift 3D
Karma/Redshift 3D
- timbolland
- 167 posts
According to the Redshift Forum the latest Redshift (2.5.41) doesn't work with 16.5. The exact message is:
“THE HOUDINI 16.5 BUILD IS BROKEN. THIS APPEARS TO BE DUE TO A PROBLEM WITH HOUDINI 16.5 AND NOT REDSHIFT
PLEASE DO NOT POST ABOUT HOUDINI 16.5 ISSUES HERE.”
Do you guys know about this? What's the SideFX view?
Regards,
Tim
Regards,
Tim
- TwinSnakes007
- 651 posts
- thexon
- 88 posts
- bonsak
- 459 posts
