hotkey for floating parameter window
   8924   10   3
I was hoping to map a hotkey to launch a floating parameter window since I'm getting tired of: Right click on operator->Focus eyes-> Find Parameters->Click on Parameters.
Inside the hotkey manager I didn't see anything for floating parameter window.
I checked help in textport and the hscript help docs to see if I can find something relevant but I don't really know what to look for here?
Is this even possible?
/Rick
/Rick
Hi Rick,
Possible, but not easy ) Basically, you have to write a script then bind it to a function key. Since I do this a lot, and I'm bored, here it is…
Petere B
popParms.hsc.zip (598 bytes)
Peter Bowmar
____________
Thanks Peter.
ahh the pane command. I was looking for window! LOL
The way I'm binding the key is with:
alias F7 `“source $HOME/popParms.hsc”`
I don't think my command is right because I keep getting a floating pane for light1 no matter what i have selected.
Cheers!
/Rick
/Rick
Hmm, that's how I bound it. Actually, if you put it in $HOME/houdini8.0/scripts then you don't need the path, but what you have should work.
To check, add this line
message $allSelected
after the “opselect()” line, that will tell you what it thinks it has selected.
You could also use “unix echo $allSelected” if the popup annoys you )
Peter B
Peter Bowmar
____________
ok I think I know what's happening here.
When the new floating pane get created it's unlinked and so happens to defualt to something in /obj. If I link the new floating pane to 1 it works.
I tried to hack the script to something like:
set newPane =`run("pane -F - l 1 -w $newWidth $newHeight ….
but that didn't work.
Digging deeper in this…..
/Rick
Ahh, yah, that sounds right. Basically, you need to set the path to each of the selected objects in the foreach loop. There's a “pane” variant that does that I believe.
You shouldn't have to link it, though.
Peter B
Peter Bowmar
____________
great thks!
/Rick
I seem to have some trouble with this….
I modified the script in the foreach loop a little bit to reflect the following:
foreach i ($allSelected)
# set the node path
set curPath = $path/$i
# echo full path to textport for i
# echo $curPath
set newPane = `run(“pane -F -w $newWidth $newHeight -P $offset 400 -m parmeditor”)`
# -h should set the node path; -a 0 hides network ctrls; -A 0 hides the pane bar
pane -n $i -h $curPath $newPane
set offset = `$offset + $newOffset`
Could you/anyone try to run the attached script on your end to see if it works on your end.
I'm having some very strange behavior.
If I drop a sphere sop and hit F2 to launch this script, it works!
Now if I select a group sop or any other sop, and hit F2, the floating pane comes up with the words “No Operator Selected.” Yes the group sop is selected! :?
Edited by - Feb. 19, 2006 21:05:59
popParms_edited.hsc.gz (598 bytes)
/Rick
ok I got it working.
I have attached it if anyone else would like it.
I made 2 fatal mistakes in my previous code.
-I should have used the expression `opfullpath($i)`
- I should have used the -H flag for pane not -h
/Rick
popParms_v02.hsc.gz (610 bytes)
/Rick
pbowmar
Hi Rick,
Possible, but not easy ) Basically, you have to write a script then bind it to a function key. Since I do this a lot, and I'm bored, here it is...
Petere B
I know it's an old post, but is this script still usable in Houdini 18.5? And how can I assign it to a hotkey/function key?
Hi, you may set the hotkey here:
Edit > Hotkeys:
Houdini / Panes / Network Editor / Node Menu / Parameters
Although, sometimes the hotkey does not work until I right click on any node. Then it starts to work again. The same applies to other hotkeys that I have in the Node Menu. Probably it is some "focus" issue.
