Rain particles going through the ground
   2180   2   0
Hi!
Houdini beginner here, I am trying to make a basic rain sim of rain interacting with an object and splashing on the ground making puddles. I am having a problem with the particles splashing on the ground, they are acknowledging that the ground is there but 50% of the particles splash against it but the rest go through it and splash just under it, i have tried using different things for the ground like a groundplane and geo but i keep getting the same problem.
Any suggestions or help would be amazing!
I Have attached the scene file if anyone would be amazing enough to have a quick look? Thank you in advance!
Rain_001.hipnc (443.5 KB)
https://www.orbolt.com/asset/SideFX::vfx_rain here
You need to increase the substeps in the POP Solver node. Basically what is happening is that some particles are intersecting the ground plane in between frames and by the next frame they are passed the ground plane and hence traverse past it.
Screen Shot 2018-05-18 at 8.52.10 AM.png (107.0 KB)
>>Kays
