How remove letters from end of a string ?
   13337   4   2
Hi;
Using VEX codes, how could I remove some letters from end of a string ?
Thanks.
Masoud Saadatmand (MSDVFX)
It's a bit tricky, I don't know if there's another way or if it's working for all cases, but the idea is here : transform your name to a string array, remove the values your don't need, and write it back to a string.
cc_CropNameFromEnd.hip (76.0 KB)
please have a look at the string manipulation functions in the docs. In your case http://www.sidefx.com/docs/houdini/vex/functions/rstrip.html [www.sidefx.com]
Note the related functions at the bottom of that page.
Edit:
Here's some further info: http://www.sidefx.com/docs/houdini/vex/strings.html [www.sidefx.com]
string a_string = "hello world!";
string thirdbyte = a_string[:-3];
result: hello wor
Hope this helps
Andy
Edited by Andy_23 - April 2, 2018 07:50:38
Andy_23
string thirdbyte = a_string;
Where can i find these expressions in the documentation?
Use functions that start with re_ . They take regex expressions and you should be able to do very complex replacements. Do you have an example string?
Jobless
