Several RBD animations at one FBX for games
   3473   1   0
I need 2 random fracture animations at one fbx
I'v created a simple RBD simulation and set parametres at Auto Dop Network
Next, I use ROP Output Driver to cache .bgeo.sc file
Then, I changed parametres at Auto Dop Network and bake new .bgeo.sc file via 2nd ROP Output Driver node
So, I have 2 bgeo.sc file sets and it's time to bake it together!
I tried to merge 2 files, but it's not work correctly. I have 2 objects enabled in a viewport at the same time. And using time wrap node doesn't give a correct result afler merge
Attachment Not Found
Looking forward for help!
RuneDestroy_005.hip (473.2 KB)
What is the error on the timewarp? It could be that you're trying to access a frame value that isn't available for that sequence so it fails. You probably need to clamp the value.
Also, do you want to see both sims at the same time or one after the other? If they should be sequential then use a switch and set a key on the switch to swap between the one and the other.
Mike
