Hi there,
I have an object merge node that works with a bunch of wildcards, this kind of thing /obj/*/OUT_Collider.
In theory it's great because I can keep adding objects with that naming convention and they will automatically be added to the object merge. The problem is they don't reliably update. Sometimes if you remove an object, it will stay in that objectmerge (for that session) and sometimes when you add a new one, it wont appear.
I heard adding this to the end might work (`substr($F,0,0)`)
Is there any way to force them to update more often? It's started to cause a few headaches as the objects in the scene aren't always reliable.
Pete
Object merge not updating automatically.
6005 6 1-
- peteski
- 546 posts
- CYTE
- 813 posts
- tamte
- 9692 posts
I feel like that's unlikely at the current design
specifying objects using wildcards is not directly a dependency on anything (unlike using bundles), as it would have to resolve the wildcards constantly to find out that it needs to include or remove some other object, which may be costly as you can have wildcarded patterns on hundreds of parameters
currently it resolves the pattern when the parameter is cooked
and since it will not magically know that the pattern now resolves in different set of paths until it cooks, it will not have a need to cook to resolve it to find out if it needs to cook to resolve it, …, sort of chicken and the egg
so obviously currently you get the correct updated paths when something else forces that parameter to cook and that's why it isn't immediate
to get immediate results you can use Smart Bundles, which will resolve pattern every time the objects in the scene change and therefore it will force all parameters that use that bundle to update therefore the node will cook, …
even though bundles have their own set of workflow issues
- peteski
- 546 posts
Hey thanks for the detailed response!
Yeah I can get why that would be a bit of an issue, it's a bit frustrating though when you are going through things trying to figure out why it's not working as expected
I mostly export to Unity though so I have added this to my export script,
for node in hou.node("/").allSubChildren(): if (node.type().name() == 'object_merge'): node.cook(force=True)
- CYTE
- 813 posts
- CYTE
- 813 posts
- peteski
- 546 posts
