storing @P to @mypos doesn't work
   3364   5   1
Hi!
I'm placing the position values in @mypos. In the same wrangle, when I check with colors to visualize it (@Cd = @mypos it works.
When I go in a wrangle (right after the first one) and try the same color check, the result is not the same. It's like it only uses the X value.
-Olivier
P_to_mypos_problem.hip (68.9 KB)
I fixed it but I don't understand why it was not working before.
At the second wrangle, I re-specified that mypos was a vector (@Cd = v@mypos).
@mypos was already a vector in the previous wrangle, why would I need to remind houdini about it?
-Olivier
Hi Olivier,
apart from a small list of reserved attribute names (like @P and @N) you need to tell houdini what type the attribute is. Replacing @mypos with v@mypos should fix things
Henry Dean
That's where I'm confused. In the first wrangle, I use v@mypos. From that point on, everytime I use @mypos, houdini should already know it's a vector, right?
-Olivier
No, Houdini doesn't do type introspection in wrangles (or in most places that touch geometry attributes for that matter), so for each fresh wrangle you need to define the types again.
Thanks.
Somehow, I never had that problem before.
-Olivier
