CurveDecorator otl not copying HDA geo
   2124   3   1
Hi! I am using HEngine 16.5.473 with Unity 2018.1. I loaded the CurveDecorator hda and it loads a Curve asset with no problem. When I load an HDA for the Mesh Object, nothing happens. I baked the same HDA Mesh Object into a prefab and then loaded that into the Mesh Object with success. The Mesh Object copies along the curve as a prefab, just not an HDA.
Is this a bug with the new engine or am I missing a step somewhere? Has anyone else had this problem? Thanks!
Glen
Just tested it and it's not working as intended. Most likely a bug with the plug-in, so I'll add to my list to look at.
seelanv
Thanks for testing it!
Glen
This is fixed in today's (16.5.489) build.
