Is there some clever way to operate on ‘edge’ level?
How to remove some inner idges?
6523 8 1-
- assignators
- 44 posts
Hey guys! Really stuck at that one. I need to remove all edges which are ‘diagonal’, i.e. I want to have only quadrals as result. I can use Point Wrangle do detect such points one way or another, but if I delete point, it randomly re-orgs geometry and I am getting wrong results. For example, if I remove central point, it is not getting rid of diagonal edges, but just snaps diagonal line to the nearest point.
Edited by assignators - June 4, 2018 14:46:55
- BabaJ
- 2164 posts
- assignators
- 44 posts
Thanks! I found out after many experimentations, that my problem is even more fundamental.
This is what I use to prepare my polygon for cutting:
Basically, I raycast from point (say, 10) and create another point in places of intersection with some edge (say, 18). So, the next logical step is to connect that point with new created point with the straight line.
This is where I fail.
If I use PolySplit, it expects vertices. If I use PolySplitwith points only, it produced the image I had before with diagonal lines and some missing cuts. Not gonna work.
But, if I add vertices along with the point, they mess up polygon immediately.
Now, in this situation, I can not simply start creating some primitives, because I have no clue. Is there really no way to create new edge between 2 points properly?
- BabaJ
- 2164 posts
Well, just from a vex point of view…
you have all the points you need to create the divisions you want.
You dont need to ray cast at all, just decide which points you want to connect to get the unique polygon shapes you want.
Post a hip, and say what you want - and if I'm on later I'll do something.
Otherwise, someone is likely to know how to do this easily with sop nodes.
- kahuna031
- 897 posts
- assignators
- 44 posts
you have all the points you need to create the divisions you want.This all wholly procedural, I have like 1000s of different shapes. So, in reality, I need to raycast and do all other stuff, because shapes are very different.
If I understand correctly: create a line between your points and feed that into the polysplits second input, your geo to the first.
Ohhh! I just noticed, that polysplit has second input 0_0 It expects some projections curve. But if that is just the line, and it will cut, I think I can manage from there, just be making forloop and feeding those lines as second input
Edited by assignators - June 5, 2018 03:13:24
- kahuna031
- 897 posts
- assignators
- 44 posts
- BabaJ
- 2164 posts
It still can be done proceduraly no matter how many different shapes.
What makes the difference is the set up, with the end result in mind and it's variations.
Then from there how the procedural process is set up is determined.
Edited by BabaJ - June 5, 2018 09:05:00
