Getting image from COP HDA Subnet [Solved]
   3881   2   0
EDIT: This has been solved! Grab Houdini 16.5.525 or higher to be able to use this.
Hey guys! I'm doing a little experiment and need a sanity check. Haven't been able to find a whole lot of information, so I'm wondering if anyone's here looked at this.
So, I have a COP Subnet HDA that's simply loading an image. However, when I try to extract it to memory and write it out to a file or have Qt load it, it looks completely washed out. Does this code look like the right method for a simple image extraction through COPs?
HAPI_CookNode( this->session, this->assetNode, &this->cookOptions);
HAPI_RenderCOPToImage(this->session, this->assetNode);
int bufferSize;
HAPI_ExtractImageToMemory(this->session, this->assetNode, HAPI_PNG_FORMAT_NAME, "C A", &bufferSize);
std::vector<char> data;
data.resize(bufferSize);
HAPI_GetImageMemoryBuffer(this->session, this->assetNode, &data.front(), bufferSize);
Regarding writing out, I'm just using ofstream:
std::ofstream file(outputFilePath);
if( file )
    file.write(&data.front(), data.size());
Notes: I attached a sample of the output. I also haven't looked through the data of the image itself to see what is exactly missing.
Edited by sburrichter - July 24, 2018 12:04:58
Could you try with Houdini 16.5.525 or newer? We might have fixed this recently.
Looks like that did the trick! Thanks guys! Attached a screenshot of the result with Qt reading the memory output. Image discrepancy is due to some leftover settings that I'm too lazy to change
Screen Shot 2018-07-24 at 8.59.16 AM.png (410.3 KB)
