RBD to FBX Exporter doesn´t update after switch Anim
   3261   2   0
Heyho,
I create currently a bigger fracture Pipeline and export this with the RBD to FBX out node.
But I have since shortly always the problem that the RBD to FBX is not updating the animation data.
If I remember correctly this was not in the beginning not happened.
I created an example what I can share, it´s really only a simple test but it shows the problem.
To recreate this Issue in the Example File is quite easy.
I created some Links at the “Source_OBJ” Node what does most everything.
-> play Timeline to see the Box Sim
-> Export RBD Box once
-> play Timeline again to see the Torus Sim
-> then switch the Fracture Objects and export as a new file the Torus Sim
If you compare those files now the Torus animation is broken and used the previous BOX animation.
Also, I tried to reset the Simulation always in-between but this changed nothing.
Currently, I can only reset it if I restart the whole Houdini Project and this is not really a good workaround for my future Pipeline.
Can maybe someone have a look, I don´t get it what´s work. Currently, I assume it´s directly in the RBD to FBX out node.
Thanks a lot, guys.
testrbd.hip (273.9 KB)
Hi Antonsfx,
We recently fixed a bug related to this in Houdini. Could you download the latest daily build and let us know if you still see it?
I wasn't able to reproduce it using your file,
Luiz
Luiz Kruel
Senior Technical Artist
Hey Luiz,
thanks that helped.
I updated to 16.5.561 and it works again. (SOLVED)
Edited by antonsfx - Aug. 13, 2018 14:25:46
