VEX Global Illumination shader error
   3092   2   1
Hi all.
Making some global illumination effects with the VEX Global Illumination light shader I get an error that I don't understand.
I want to change the environment map orientation using a Null object, so I create a new Null object and set the path to it into the Null Object parameter of the VEX GI shader, then every time I launch a render I get the next error in the terminal:
Warning: can't find object named ‘/obj/orientGI’ to compute transform
I have checked the path to the Null objetc and it is correct, and checked in the ROP parameters and Visible Objectd is set to * so theNull is included in the render.
Why this error happens?
Thanks.
Un saludo
Best Regards
Pablo Giménez
Are you turning on “Output transform as Render Space” on the Null's Render Tab?
Thanks Wolfwood, now it works properly.
Un saludo
Best Regards
Pablo Giménez
