I was looking at an example file on how to use pop replicate.
In it the person preceeded pop replicate with a pop stream node.
In that node they define what seems to be a local attribute/variable to be used by the network to decide if pop replicate will emit.
It's a very usefull approach and I'm glad I found it as it's what I needed for something I was working for.
The thing is, unless I came across this example file, there is no way I could have found this out through reading documentation.
I can find no references to ‘ingroup’ anywhere.
I've looked under standard pop local vairables:
http://www.sidefx.com/docs/houdini/nodes/pop/popLocals.html [www.sidefx.com]
and under the POP stream, POP Replicate, POP Network and POP Solver docs; but no reference to ‘ingroup’ anywhere.
This is a curiosity at this point, but I might point it out to support if no one knows where the reference is.
Anyone know where this might be referenced in the docs?
Pop Stream with 'ingroup'
1647 3 0-
- BabaJ
- 2166 posts
- tamte
- 9407 posts
it's just how streams work
http://www.sidefx.com/docs/houdini/dopparticles/streams.html [www.sidefx.com]
http://www.sidefx.com/docs/houdini/nodes/dop/popstream.html [www.sidefx.com]
- tamte
- 9407 posts
- BabaJ
- 2166 posts
