I wrote this node so that I had an easier time with using an object input/output hierarchy where I wanted the object connections to be “in spirit alone,” so to speak. Basically I was having problems with simply using “ignore parent” and “child compensate” attributes, so I finally resorted to delving into the HDK, and found that controlling the transformation matrix in a OBJ_Node plugin is a whole lot easier than with Maya's MFnTransform/MFnTransformationMatrix API.
Basically, if you don't want to send or receive transformation matrix data, you just have to return an identity matrix for both the applyOutputTransform [www.sidefx.com] and applyInputDependentTransform [www.sidefx.com] overrides.
As a result, I can now use the objects in my hierarchy to control not only the locations of points for a polyWire node, but I can also apply a non-uniform rotation and/or scale without affecting the child/sibling nodes and without loosing the hierarchy network! I suppose there's a way to do this with assets, subnets, chopnets, etc…but as I'm still basically a novice to Houdini, this seems to be the least painful approach.
I'm not yet sure what other benefits such a node could have, but I'm open to suggestions. I can't compile for Win/Mac, but here's the source/scene/Linux DSO if anyone's interested…
(PS: the emb-notation stands for Escher-Muybridge: They are both names I decided to use for my fantasy Rigging and Animation software, but I incorporated them here as well, since I couldn't figure out any other convention to use for this project…)
My First Houdini Plugin: An World-Only Object Node
2321 0 1-
- HongMao
- 63 posts
