Stacked group of objects stacking problem.
   3841   4   1
Hi all.
I am currently trying to create a stacked group of boxes. I have the heights of the boxes imported through a CSV file fine.
I thought that maybe using a for loop in an attribute vop to add the values together over each iteration could be a way to go, however, I can’t seem to make the values progressively accumulate over each iteration.
I have attached a file on where I am at.
Any help on this would be greatly appreciated.
Paul.
Edited by hitch - Sept. 12, 2018 19:11:24
tempData.csv (51 bytes)
stacking.hiplc (100.4 KB)
Here is the basic code setup for adjusting the Y location. But you may need to adjust the height of the boxes as well.
ap_stacking.hiplc (110.1 KB)
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
@Enivob. Thank you so much. All I had to do was adjust the pivots for the boxes this worked perfectly.
I am clearly going to have to get over my code phobia and learn some vex.
Hitch.
Funny, was thinking about this problem a few days ago, came up with a more general solution that might be useful:
http://www.tokeru.com/cgwiki/index.php?title=ForLoops#Stacking_boxes [www.tokeru.com]
@mestela. That is awesome. I am going through digesting that now, thank you very much.
