spiral effect particles very very urgent please need some help
   2854   6   2
Hello I have a really complicated client to manage who asks me to make him realize this effect.
https://vimeo.com/175110608 [vimeo.com]
How I can do this to him under houdini please? I swear it's really urgent that I do this to him for Monday for the last month he's been pressing me like a lemon…
I need to use this whit C4d link
thank you for your help !!
Edited by bgood - Sept. 21, 2018 10:06:36
Sorry for my english but i learn too ^^
1 ryzen 3970X 64go
1 xeon hexacore 32go
1 i7 hexacore 16o
My computer is tied up with a render right now and I don't have enough memory to start another client to give you an example.
But Scott Pagano has a paid tutorial that you can skip to the essential parts you need;
https://www.lynda.com/course-tutorials/Welcome/503812/620206-4.html [www.lynda.com]
If you've never had a lynda account, I think you can sign up for a free trial so that you can at least go through this tut without having to pay.
I forget how he actually does it as there some possible variation in approaches.
But I did something like your video clip using a straight line that is animated ( position and rotations ).
With a popnet after set with constant point activiation then followed by an add node which lets you connect all the points in a line that shared the same emission point source.
Then with vex running over prims you can with color ramps and fitted(points along prim ‘distance’) float ramps, determine each start/end for variance of length and color.
Edited by BabaJ - Sept. 21, 2018 10:53:46
It is also possible (likely even looking at their other animations) it is done using a moving texture on deforming geometry. Nice looking piece. If it is “really urgent” maybe you should try subcontracting the job to Ari.
Thank you my friends for your lights, unfortunately I can't make another person work, the budget is really low, and the customer is not correct at all ( a bank…) but thanks again I think I have found the solution
1 ryzen 3970X 64go
1 i7 hexacore 16o
MOPs might also be able to tackle something of the sorts that wouldn't be 100% the same, but maybe close enough for your client.
On a related note, if you're client is 1. cheap, 2. impatient, and 3. not correct at all; you might want to reconsider working for this person.
https://www.motionoperators.com/video-tutorials-2/ [www.motionoperators.com]
>>Kays
Good evening, thank you for your feedback. It is obvious that I would no longer work for this customer, but I want to remain professional until the end and deliver his order… First and last time I work for him, in the end I found the tutorial to do this effect under c4D I would be more efficient there than under houdini that I am learning
https://www.youtube.com/watch?v=mOMRJvaD7kU [www.youtube.com]
1 ryzen 3970X 64go
1 i7 hexacore 16o
I kinda gotta admit that C4D still kicks Houdini's ass when it comes to ease of use to achieve these types of effects. This is all quite doable in Houdini for sure, but I don't think it's as easy and straightforward as following a 4 minute tutorial for C4D.
>>Kays
