Vellum / Attach to geometry - Animating the Stretch stiffness scale value.
   5303   3   3
Is such a thing possible? It seems to keep the value it has at the Attach Frame.
Edit: Found this similar question:
https://www.sidefx.com/forum/topic/58607/ [www.sidefx.com]
Can't find a constraints property node though.
Edit 2 : Nevermind, was one level too high. Anybody wondering, this works if you create a group for your constraint and animate the value in a constraint property node, inside the Dopnet that's inside your SOP vellum solver.
Edited by Tanto - Nov. 14, 2018 17:47:35
Tanto
it's in dop level
or if you are using Vellum Solver SOP, just dive inside, it'll take you to the DOP network subnet that can be used for this purpose
Thanks tamte! Figured it out at the same time.
Hello Tamte and Tanto.
Also I am looking for a way to animate stretch stiffness scale values, preferably through a keyframed re-ramp (something I would normally do in a pointVOP. When I insert a constraint property node though, it doesn't show the property ‘stretch stiffness’, as far as I can see. Let alone how I could use a re-ramp parameter. What would be the way to go?
