find degrees between 2 vectors
9934
4
0
olivierth
Nov. 15, 2018 5:20 p.m.
Hi!
I'm testing a detail wrangle that should find the angle in degrees between 2 vectors but the result is off. Where's my mistake?
vector v0 = normalize (set (-1 ,0 ,-1 ));
vector vref = set (0 ,0 ,-1 );
float dot = dot (v0 , vref );
float radians = fit (dot , 1 , -1 , 0 , $ PI );
float angle = degrees (radians );
f@rotation = angle ;
-Olivier
BabaJ
Nov. 15, 2018 5:59 p.m.
Dot product alone isn't enough. In my sample file I've commented on the single line that does it. The rest you set up differently to however it works for you.
Angle Between Two Vectors v1.hiplc (70.8 KB)
olivierth
Nov. 15, 2018 7:19 p.m.
Ah!
So I had to do this:
float radians = acos (dot (v0 , vref ));
-Olivier
wlvl
March 29, 2020 6:49 a.m.
In case is helpful..
If you want the rotation value in degrees for each axis component.
vector v0 = normalize(set(-1,0,-1)); vector vref = set(0,0,-1); vector4 orient = dihedral(v0, vref); vector angle = qconvert(orient); angle = degrees(angle)*-1; v@angle = angle; You could reference the angle attribute in the rotation parameter of a transformSOP.
tag: rotation in degree for each axis component from direction vectors
tamte
March 29, 2020 11:53 a.m.
wlvl If you want the rotation value in degrees for each axis component.... vector angle = qconvert(orient); angle = degrees(angle)*-1; ... that doesn't sound correct
qconvert() will convert quaternion to angle/axis vector representation and that's different from per axis euler angles
to get actual euler angles you'll need to use quaterniontoeuler instead
... vector angle = quaterniontoeuler(orient, 0); angle = degrees(angle); ...
Edited by tamte - March 29, 2020 11:59:07
Tomas Slancik CG Supervisor Framestore, NY
