Hello everyone,
I'm a Houdini Junior and I'm building a small tool in Python to help me out with repetitive tasks. In my pipeline, I need to import really often alembic from Maya, that I will then use for examples as collider for my simulations. I usually have to manually select all the geometry from the alembic and create a new geo node with an object merge inside for each part of the alembic that I need. I'm trying to build a shelf tool that will manually do this for me. Searching online, I found a tool that I'm changing to achieve my personal tool. I'm a noob at Python and I'm doing my best to learn it.
After getting part of the code right I got stack at this point. I need to connect all the children inside an object to a merge node. This is what I've got:
for i in hou.node(“obj/destination/”).children():
hou.node(“obj/destination/merge”).setNextInput(hou.node(“alembic”), merge_index=0, unordered_only=False)
I'm pretty sure is completely wrong. There's anyone with good Python knowledge that can help me out?
It would be amazing
Thank you
Alice
Python Tool for import alembic
4971 3 1-
- Iamgroot93
- 51 posts
- goldfarb
- 3465 posts
- Iamgroot93
- 51 posts
goldfarb
might be helpful to see the whole script you using…
you can use:for i in hou.node(“obj/destination/”).children(): merge.setNextInput(i)
hope that helps
This is all the script but I still did not modify it. I've modified a script of another Houdini user and I'm trying to change it
#Create empty geo node:
destination = hou.node(“obj”).createNode(“geo”, node_name=“destination”)
#get all alembic archive nodes and put them in to a list:
alembic_archives =
for i in hou.node(“obj”).children():
if i.type().name()==“alembicarchive”:
alembic_archives.append(i)
#get alembic geo nodes inside alembic archives
alembic_nodes=
for i in alembic_archives:
for x in i.allSubChildren():
if x.type().name()==“alembic”:
alembic_nodes.append(x)
#copy alembic nodes to destination geo node
hou.copyNodesTo(alembic_nodes,destination)
#remove leftover alembic archive nodes
i.destroy()
#create a merge node, move the display flag and move into a good position
merge = hou.node(“obj/destination/”).createNode(“merge”)
merge.setDisplayFlag(True)
merge.moveToGoodPosition()
alembic_children=
# Get sopNodeType for the file SOP
file_nodes = hou.nodeType(hou.sopNodeTypeCategory(), “file”)
- Iamgroot93
- 51 posts
