Displace along normals for-each problems...
   1539   1   1
How to connect disconnected pieces after for-each nodes&. it's will be a planet/ where will be texture each pieces separately.
Sphere_displace_part.hipnc (190.8 KB)
Screenshot (6).png (949.0 KB)
I'm not sure what the loop is for in your setup, so I removed it. It's generally easier to avoid splitting up sections than to try to put them back together again.
In place of facet/connectivity, I use an enumerate to assign an id to each face before subdividing. Then the section can be split apart after the noise/subdivision is applied.
Sphere_displace_part2.hipnc (205.7 KB)
