Bend multiple lines separately
   5046   6   0
I copied some lines onto a geometry.
How can I bend them separately?
So far, I tried the copy stamp option and
several for loops, but I cannot get this to work.
I can imagine doing this in an attribute wrangle,
but I guess there's a much easier (node) option.
Could anyone please point me to the right way
here, please? Thx.
Just to clarify, this approach was probably my best one (lol).
How can I copy one of the many lines to my scattered points?
here is example using the “for-each-nodes”. The idea behind is using the metadata to create attributes for each iteration. These attributes can be used to perform a single operation for each iteration and after this the result can be merged to the feedback result of the loop.
scatter_bend.hipnc (110.0 KB)
This might be an interesting read too
https://forums.odforce.net/topic/25760-curling-hair-curves-with-vex/ [forums.odforce.net]
cheers
Guide Process SOP could also be an option for bending curves:
-b
http://www.racecar.no [www.racecar.no]
Ah great, thank you all!
That'll keep me busy for days
I now understand much more about all this stuff.
Here's my “move to points” solution.
