Sometimes i get stuck at the docment, if have a sample, it will save many times.
Thanks.
Could you please add a Heightfield hda sample in the houdini engine for ue4?
5409 6 1-
- ChenA
- 25 posts
- DougRichardson
- 29 posts
- ChenA
- 25 posts
- DougRichardson
- 29 posts
Sorry ChenA, I just saw your reply (apparently I wasn't subscribed to this topic).
In UE4, your Houdini Asset should have a section called “Houdini Asset” in the UE4 Details window that has a checkbox to “Enable Cooking on Parameter Change.” Make sure that is clicked or, if not, you will have to press the “Recook Asset” button after you've made changes.
Is that what you are asking? Or are you asking about sending UE4 objects over to Houdini to use as input parameters in Houdini (because if so, I haven't tried that out yet)?
- ChenA
- 25 posts
- DougRichardson
- 29 posts
- samuelbrunner
- 38 posts
