Easy Procedural Grid Array? Like a 3x3x3 LED Cube
   3787   9   0
Is there an easy way to get a cube with interior divisions? I want to be able to get points from them so I could get points like on a LED Cube.
box with divisions 3*3*3
Jim Rutherford
But I will not get any points inside the cube. Where I circled.
Edited by animationalex - March 15, 2019 15:21:12
try 2x2
Training Lead
www.sidefx.com
sorry..should have said 2*2*2 divisions….should look like this…make sure you use a polygon cube…I think you used a nurb.
Edited by Jim Rutherford - March 15, 2019 16:05:29
Jim Rutherford
Ah, got it. Thanks so much!
Is there a way to put faces on the edges? I want to cut up geometry into cubes with Boolean Fracture.
Edited by Brian L - March 19, 2019 13:36:30
Not really, the layout of those primitives are a bunch of straight line segments, not squares ready to be filled in.
Here's an alternative approach of copying grids to lines, might be useful.
slicing_box.hip (72.4 KB)
mestela
Thank you. This works great. I was doing something similar with MOPS Instancer, but this is much more elegant and I'm assuming ‘cheaper’ because it's using low level nodes.
Mmmmmaybe more efficient, but not enough to worry about. Plus mops has all the cool features for modifying and animating your instances, my one is pretty spartan!
