Hello, Everyone
Iwanted to ask, how can one go about creating this kind of Unfolding Polygons animation
as seen in the picture attached and at the link below:
I have attached the file
http://www.tokeru.com/cgwiki/?title=Houdini#Unfolding_polys [www.tokeru.com]
I am trying to do such an animation using the for each named primitive loop but im failing
And the keyframes i set using a detail makes the keyrames to be stepped instead of bezier
because the rotation just jump from value to value no transition in between
Is it simple to setup?
Thank you very much and looking forward to your response
Houdini Unfolding Folding Polygons animation
5199 6 2-
- henrythejedi
- 61 posts
- mestela
- 1857 posts
- henrythejedi
- 61 posts
mestelaHi mestela
I looked at your hip, but I'm not sure what you're trying to achieve. Can you explain the outcome a little more clearly?
Thanks for checking up my hip file
I am basically trying to recreate exactly the same animation as seen in the little gif animation i have attached above
but i want to use for each loop instead
In the animation, polygons appear to fold one after the other until in the end they create a complete shape
its almost like a domino falling effect
TI winder if for each loop can do this because it can make it simpler
Thank you
- mestela
- 1857 posts
- henrythejedi
- 61 posts
- mestela
- 1857 posts
- henrythejedi
- 61 posts
mestela
Ok here's 2 versions, the one on the left is how I'd probably do it, the one on the right is I think what you're asking to do.
mestelaOh My Goodness You Did it Mestela
Wow, you even did it with code in attribute wrangle
I dont know how much to thank you sir
Thank you very much by providing 2 examples as well
wow
