ViewTaskOutput can't find file if not on C:/ drive?
   4484   5   1
Hi I tried to follow the PDG for Indie Gamedev tutorial but I'm running into some problems when I try to “ViewTaskOutput”. It works fine when I set it up on the C drive but when I store my project on another drive I can't get it to work and it keeps giving me this error.
houdini viz error.PNG (15.2 KB)
This is a known bug on Windows. In the mean time, you can click on the output link in the Task Info window.
Thank you for the quick reply seelan. I'm also having some issues getting the output to be displayed in unity when running on an external harddrive. Is this known to also be an issue? The outputs cook and are genenerated but nothing is displayed when the project is not stored on C:
Is this a TOP network in an HDA, and using PDGAssetLink? Or just the regular unity plugin?
In tomorrow's daily build, View Task Output will work on generated files that are on mounted drives on Windows.
It is Top network in an HDA with PDGAssetLink i believe. Following the example by Kenny Lammers.
Great! Will be sure to check it out.
Thanks again Seelan.
