I consider using Houdini. However, because it will take a lot of investment, I am doing extesive search in advance.
My question for now is, whether for Houdini is more natural to use Mental Ray or RendeMan? I have read that it is possible to use both renderers, and both of them are of about the same quality but they are still a bit different in shader developement and programming.
Thank you,
Rene.
RenderMan or Mental Ray with Houdini?
20449 20 5-
- Bunkai
- 38 posts
- symek
- 1390 posts
Houdini is little more sutable for using with RenderMan but it easly can work with both of them + its native render engine called mantra. RenderMan is really sewed in to H. also in shader development pipeline but mental doeasn't stay too far from that.
These differences means nothing if you really are interested in investing/building pipeline/using one of them…
You should also look toward Air, RenderDoc or others RenderMan compiland engines if mantra doesn't satisfy your needs.
On the other hand I would consider mantra as a first choice renderer since it's much more powerful then most beginners suspect. Have you ever tried mantra seriously? What drives you to considerating others? Why bother with RM or MR? What is a reason to spend another 5K$ if Houdini comes with great render supply? (5K$ * 10 - since Houdini Master comes with 10 render licences as I remember). Are you ready to spend another 50K$ for mental or RenderMan? You must have a reason!
cheers,
SY.
cheers,
SY.
- Bunkai
- 38 posts
Hello SYmek,
Thank you a lot for answer. Well, I use XSI, so the Mental Ray license shoudl be applicable, and if I want to compose images, with already MRay rendered scenes, I thought MRay woudl be the best choice for Houdini.
Indeed, yes, I have never tried Mantra. Considering a new thing is always a matter of time to me, and since I realize tha MRay and RMan are two most powerfull things. However, yes, I bellieve, Mantra is worth of trial, and if it is really recomended I will try it then.
Thank you, with regards,
Rene.
Rene.
- pbowmar
- 7046 posts
I'd personally go with Mantra, it's very mature and pretty robust. It is also far far cheaper than PRman or Mental Ray ) We used it extensively on Superman Returns at Rhythm and Hues, all the ocean, boat, helicopters and a bunch of other stuff during the part where Superman rescues them from the boat.
PRman and other PRman-compliant renderers would be my second choice. I'm not a fan of Mental Ray because of the lack of shading language (sorry, C isn't a shading language, it's a general-purpose language) and the sluggish, sluggish motion blur. That's not to say it doesn' t make nice images, it certainly does, but is it fun to work with? )
Peter B
Peter B
Peter Bowmar
____________
Peter Bowmar
____________
- craig
- 557 posts
- diula
- 63 posts
Unless things have changed recently (but I/m pretty sure they didn't) you are not able to use your existing xsi mental ray licenses to render with Houdini. With XSI you have a license for the library version of mental ray, and to use mr in Houdini you need the standalone software (or BatchUniversal, if I/m not mistaken).
I would advice on sticking with Mantra, since it is indeed an extremely flexible and fast renderer (ok, minus some GI quirks), and best of all, it is very easy to code shaders for it, if somehow VOPS is not enough for you…
If you decide to go the renderman way, 3Delight is the best choice IMHO - both as stability, features and price…
As far as mental ray itself, even though I am a fan of it, I would advice to not use it…Reality is that it is quite problematic for heavy scene rendering…Even if the speed of mb has been dramatically improved with the rasterizer, it has some glitches with sec. buffers and transparency, and many more little quirks.
Cheers and good luck with the transition
- symek
- 1390 posts
We can make this conversation as long as we want
. There always can be another point of view altghough it seems that there is no disagreament here yet. I can tell you like this: there is a big strike about first place between MRay and RMan and I don't care who is a winner because I'm sure who is on the third place…. and that is mantra
cheers,
SY.
.cheers,
SY.
- Bunkai
- 38 posts
Thank you all for your valuable information. Yeah, it really helps to read from experienced people, and indeed, I have never heard about 3Delight and therefore, now I know another new and nice renderer - that is RenderMan compliant.
I will need couple of days to do some more search and to decide, however as you all recomend, if Mantra is OK for most rendering, then fine, why not to try it. :-) It is worth of doing it.
Thank you a lot and have a nice day,
Rene.
Rene.
- Bunkai
- 38 posts
There is one more question that came to my mind: Is Mantra shader development somehow similar to RenderMan shader development? Can, say documentation on RenderMan shader development ( an example, a book: Photorealistic RenderMan) be used to learn Mantra shader development?
If yes, how much the Mantra shader development is deviated from RenderMan one?
Thanks and have a nice day,
Rene. :-)
Rene. :-)
- symek
- 1390 posts
It's almost the same story! Really! In case of simply shaders you can almost automaticly change variables names and functions to translate RSL->VEX and vice vera! Check out some famous RSL shader and its convertion to VEX (like UberLight by Larry Gritz - http://odforce.net/codex/?page=4&sec=all&catlimit=&sorty=&limit=5 [odforce.net] at the very bottom)
There are of cource many differences but you shouldn't worry about that right now
cheers,
Sy
cheers,
Sy
- Bunkai
- 38 posts
- Bunkai
- 38 posts
Diula,
I've just noticed that 3Delight is a free package. What a surprise. Thanks for good tip.
Indeed, developers claim on 3Delight website, that the following dog's head has been rendered with 3Delight. http://www.3delight.com/Gallery/Collection/01A/Bailey_HR.htm [3delight.com]
That dog's head seem to me to be so real, that I can hardly bellieve it is a render. Any thoughts?
Edited by - Oct. 8, 2006 10:27:06
- symek
- 1390 posts
- terrybuchanan
- 31 posts
- diula
- 63 posts
- edward
- 8081 posts
- Bunkai
- 38 posts
- diula
- 63 posts
- Bunkai
- 38 posts
- symek
- 1390 posts
