Hello ! I'm testing the new Vertex Animation shaders for Unity LWRP and getting this issue.
When i import Gametools VAT LWRP shaders into Unity i'm getting this errors
Shader error in ‘sidefx/lwrp/VAT Fluid Simple Lit’: unrecognized identifier ‘posTex’ at Assets/SimpleLitVATFluidInput.hlsl(39) (on d3d11)
Shader error in ‘sidefx/lwrp/VAT Sprite Simple Lit’: unrecognized identifier ‘posTex’ at Assets/SimpleLitVATSpriteInput.hlsl(40) (on d3d11)
Shader error in ‘sidefx/lwrp/VAT Soft Simple Lit’: unrecognized identifier ‘posTex’ at Assets/SimpleLitVATSoftInput.hlsl(39) (on d3d11)
Shader error in ‘sidefx/lwrp/VAT RBD Simple Lit’: unrecognized identifier ‘posTex’ at Assets/SimpleLitVATRigidInput.hlsl(36) (on d3d11)
And when i try to create new material - there is no sidefx folder in shader selection list. All shaders found in Failed to Compile section.
Unity 2019.1.0f2 clean project
Windows 10 64
I Have Core RP, Lightweight RP and Shadergraph packages installed, LightweightRenderPipelineAsset created and assinged in project settings.
Can i get some help with this issue ? Maybe i'm doing something wrong ?
Thank you !!!
Vertex Animation shaders for Unity 2019 LWRP not working
8157 9 2-
- IceBar0n
- 14 posts
- mikelyndon-sesi
- 394 posts
- IceBar0n
- 14 posts
Lines 25 and 26 looking like this
TEXTURE2D(_posTex);
SAMPLER(sampler_posTex);
Also tested on 2019.2.0a13 , seems that shader compiled, no errors, but vertex animation on my asset isnt working anyway..
I noticed he difference in package versions between 2019.1.0f2 and 2019.2.0a13
2019.1.0f2 package versions:
LWRP version 5.7.2
Core RP Library version 5.7.2
2019.2.0a13 package versions:
LWRP version 5.2.3
Core RP Library version 5.2.3
Maybe this will help to figure out whats causing the issue
TEXTURE2D(_posTex);
LWRP version 5.7.2
LWRP version 5.2.3
Edited by IceBar0n - April 25, 2019 10:13:22
- mikelyndon-sesi
- 394 posts
- IceBar0n
- 14 posts
Tried on fresh project.
Still not compiling, reinstalled Unity 2019.1.0f2 just in case and no luck…
UPDATE: Tried on another machine, the same problem.
I've recorded short video of what i'm doing step by step, hope this help.
video [vimeo.com]
I have a feeling that i'm doing something wrong, because you said that all working fine on your machine.
If so then my apologies in advance
UPDATE 2 Tried on Unity 2019.1.2f1 on 3 different computers and still no luck, the same errors
Thank you
Denis
video [vimeo.com]
Thank you
Denis
Edited by IceBar0n - May 14, 2019 07:14:24
- mikelyndon-sesi
- 394 posts
Unity changed their underlying code in 2019 which broke the VAT shaders. Try using this package [drive.google.com]
I've also updated the code in the github repo so there's source for Unity 2018 and 2019.
- mephistonight
- 4 posts
- mikelyndon-sesi
- 394 posts
- jordaneast
- 8 posts
- nehvaleem
- 1 posts
