Please help, bathymetry OSM import is giving wired results
   3105   2   1
I have tried to import bathymetry in OSM format via the OSM import node form the GameDev tools. The .osm file I use, is generated by this tool:
Srtm2Osm [wiki.openstreetmap.org]
It is an area of 50km around south Oahu
The general shape seems to be correct, but it is way to small and in a really wired position around X:between 5570 and 5620 Y: between -39220 and -39270.
May be the .osm file is missing some attributes, the script needs, to scale it correctly and center it in the scene?
Edited by W7R - April 25, 2019 17:39:00
srtm.osm (7.9 MB)
Hey W7R
You can drop a axis align node after the OSM if you would like it to be centered.
It's looks like it's missing a bounds attribute which the script uses to center the incoming data.
Luiz Kruel
Senior Technical Artist
lkruel
Hey W7R
Hey Luiz,
thank´s for the great tip , it is really a steep learning curve, but def. worth it!
I think you guys doing a really great job over there, awesome software.
br
Stefan Andres
