Custom Partitioner: Zip around primary input
   3763   2   1
I'm trying to find existed partitioner where you can make dependencies around a primary node and all other workitems (like a zip function). Do you have some partition with similar behavior?
Example hip with custom partitioner in the attachment or just python snippet.
node_map = {}
for work_item in work_items:
    if not work_item.node.name in node_map:
        node_map[work_item.node.name] = []
    node_map[work_item.node.name].append(work_item)
# genericgenerator1 - could be defined as a primary input
# genericgenerator# - all other nodes
for work_item in node_map['genericgenerator1']:
    partition_holder.addItemToPartition(work_item, work_item.index)
    for i in node_map['genericgenerator2']:
        partition_holder.addItemToPartition(i, work_item.index)
Ostap
pdg_custom_partition.hip (112.4 KB)
Screenshot from 2019-05-12 20-06-03.png (34.4 KB)
I think what you want here is a partitionbyindex node with Primary Input set to By Index and Secondary Input set to All.
Oh! That is right.
Thank you
